g-code et altium
rle , 12-12-2019, 01:25 AM
bonjour, quelqu'un aurait-il une solution à proposer pour la commande d'une cnc en G code avec les fichiers drill ou gerber de altium
hello, would anyone have a solution to propose for ordering a G code cnc with drill or gerber files from altium
robertferanec , 12-13-2019, 01:56 AM
I have not tried that, but I would expect, that you may need to create Gerber files from Altium and then there should be a way to transform gerbers into CNC (that process may be specific for your CNC machine software).
rle , 12-14-2019, 12:21 AM
thanks for your answer, I have already tried with gerber files and negative results,
I guess the procedure I use is not the right one.
rle , 12-23-2019, 01:05 AM
altium and g-code
Hello, problem solved.
with the flat-cam software, I was able to convert the altium gerber and excellon file to g-code without any errors.
