Default Blank Sheet Template doesn't show up in AD22
mulfycrowh , 08-12-2022, 05:56 AM
Hi everyone,
I set up the directory for my schematic template file in Preferences > Data Management > Templates.
The template file is highlighted.
When I go to Preferences > Schematic > General, I only have "Default Blank Sheet Size".
I don't have "Default Blank Sheet Template or Size".
So I am not able to set the name of the template file.
When I create a new schematic file, it is with the default template, not with the one I want.
Any idea ?
Thanks.
qdrives , 08-12-2022, 02:51 PM
Have you set the correct settings:
- Server and local
- local templates folder
mulfycrowh , 08-12-2022, 03:13 PM
@qdrivesYes I have
qdrives , 08-13-2022, 03:24 PM
Ah yes (I should read better), that only has (paper) sizes (as the caption states).
You either need to set the (default) template as shown in the screenshot above or change the template of the (selected) sheet itself.
Make sure that you have nothing selected on the schematic sheet.
In the properties panel, General Tab, Page options select template and select the template from the list.
