About plugged vias under BGA
mulfycrowh , 06-29-2023, 11:48 AM
Hi everyone,
I have a BGA.
The manufacturer is asking if I want plugged vias.
I only have 2 vias for the fan out.
At present time, they don't have any via type according to IPC 4761.
I usually ask the vias to be covered with solder mask.
What are the pros and cons to declare the vias as plugging vias.
There are 4 different types of plugging vias in AD.
Which one do you suggest?
Thanks.
qdrives , 06-29-2023, 01:12 PM
The is a lot of thing to be said about vias and their covering.
One of more interesting page that mentions this is this one:
Vias are plated holes that connect signals between layers, and are typically smaller than ordinary plated holes that are used for soldering through-hole components.
But there are multiple, like
https://www.eurocircuits.com/blog/so...emical-nickel/The main downside of the IPC 4761 via types is their additional cost.
robertferanec , 06-30-2023, 08:10 AM
mabye is not that because some of your vias are touching the pads?
