Starting blank it can be interesting to say I need to 13k3 1% resistor, max 10mW. For the layout you pick a 0402 one.
You finish the schematic, do the layout. No you need to order.
When will you add more detail?
Do you let the manufacturer pick any 0402 13k3 1% resistor?
How about the capacitors? Inductors? Diodes?
Diode package? It is not like resistors where the size is either driven by power or voltage.
For the capacitors -- what about temperature? DC bias? AC bias? Tolerance?
For these 'simple' components it might still work, but would you do the same for the buck regulator and the microcontroller?
If not, then why do it for the other components?
If you fill in the details at the end and put it in your library. For your next design, will you again start with the generic component or pick the already detailed one?
If you then use the detailed one, then why not put in the detail to begin with?
What details do you put in the library?
You are not the first to go through this process:
I saw in a course by Mr Robert that he creates ALL components in the schematic library each time, can't I just reuse components I've previously created? and is it bad to just place the component and modify it's parameters in the schematic itself, instead of creating a new one?to explain it better, for example, Instead of
When coming to components like LEDs, resistors, capacitors e.t.c there are throngs of manufacturers and suppliers that provide parts that are very similar from PCB design perspective i.e the schematic symbol and footprint. What approach then does one take when designing parts libraries?Lets take an example, lets say I have a
My recommendation is to create a detailed symbol for each component you need before you place it on the schematic.
You also make/assign the footprint at that time to prevent the situation that there is an unknown element when you start with the layout and it may push you to select another component.
