About to change the filename for a graphic box
mulfycrowh , 11-15-2018, 02:45 AM
Hi everyone,
I drew a schematic with a graphic.
In the mean time, I changed my HDD for a bigger size HDD and changed the letter associated ( E: instead D
Now I'm getting a warning because Altium doesn't find the location.
How can I browse again to give the correct location ?
Thanks a lot.
mulfycrowh , 11-15-2018, 02:53 AM
To be more precise, it's a component with a graphic associated, in this case a battery pack.
Paul van Avesaath , 11-19-2018, 02:02 AM
I had the same problem, I now use a folder inside the Altium file directory called images. this way even If I copy the folder to a different location it can find it
robertferanec , 11-19-2018, 04:45 AM
Exactly as @Paul van Avesaath is suggesting, place images into your project directory and then be sure, when you double click on the image in schematic, it is not using full path (eg. C://xxx/yyy/image.jpg), but relative path instead (e.g. image.jpg).
