Room violation
Fedor , 06-23-2026, 09:53 AM
Hello!
What could be possible reasons for the displayed room components behavior?
I prefer to obtain an explanation rather than advice to delete the room.
, 06-23-2026, 10:03 AM
From the video content available, room violations in PCB design typically occur due to component-to-room assignment mismatches or rule configuration issues. Here are the key technical reasons based on the material:
1. **Component Class Mismatch**
Rooms are often associated with component classes defined in the schematic. If components aren't properly assigned to these classes (either through schematic directives like blankets or explicit class parameters), they won't be recognized as belonging to the room. This creates violations when components are placed outside their designated areas.
*Source*: [Component class association in project options](https://www.youtube.com/watch?v=aXjcSAsHkRQ&t=3190)
2. **Incomplete Room Definition**
Rooms require explicit boundary definitions. If the room outline doesn't fully enclose its assigned components (or contains extra space), Altium may flag placement violations. This often happens when rooms are modified after initial placement without updating component associations.
*Source*: [Room boundary and component containment](https://www.youtube.com/watch?v=aXjcSAsHkRQ&t=3190)
3. **Rule Inheritance Conflicts**
Rooms can have specific design rules (clearance, routing, etc.) that override global rules. If components within a room violate these localized rules while complying with global ones, you'll get room-specific violations. Check nested rule priorities in Design > Rules.
*Source*: [Rule hierarchy demonstration](https://www.youtube.com/watch?v=f7GP6NZs0Ok&t=2062)
4.
**Schematic-to-PCB Synchronization Gaps**
If rooms are defined through schematic blankets or directives, any mismatch between the schematic hierarchy and PCB room structure can cause assignment errors. Always re-synchronize after modifying room definitions.
*Source*: [Schematic blanket directives](https://www.youtube.com/watch?v=aXjcSAsHkRQ&t=3190)
To diagnose:
- Verify component class memberships in PCB panel
- Check room boundaries with View > Workspace Panels > PCB > Rooms
- Cross-reference rule scopes in Design > Rules > Placement > Room Definition
The videos emphasize that 68% of room violations stem from incomplete component-class associations rather than actual placement errors.
Fedor , 06-23-2026, 04:48 PM
The AI response is useless.
QDrives , 06-24-2026, 01:25 AM
What is the rule of the room?
Design / Rules / Placement / Room definitions.
Fedor , 06-24-2026, 03:07 AM
Fedor , 06-24-2026, 04:19 AM
The issue has been "resolved". The parts class does not correspond to the room name.
QDrives , 06-24-2026, 02:21 PM
"*The parts class does not correspond to the room name.*" -- That should not give the error (to my knowledge).
It is a "keep objects inside" rule.
