Schematic help
Shubham , 04-11-2024, 10:42 AM
Hi
I want to connect multiple 30 pins names as VIN_1 to VIN_30 to single 48V Power Supply followed by decoupling capacitor to with Bus. How to make this schematics without manual netlabel
Mini , 04-11-2024, 01:05 PM
What you mean by manual net label?
I think something you want is called net tie. https://www.youtube.com/watch?v=MgbO0iysi6I
Shubham , 04-11-2024, 01:31 PM
No, I want to Connect single Input Port to to Multiple VIN pins of the IC . One way I'm doing this that I'm converting the Symbol into Sheet Symbol connect to all VIN to Bus with Bus Entry after that Same bus connect to port of the VIN Sheet.
Mini , 04-11-2024, 05:11 PM
I still don't understand your problem. Maybe someone else can help you. I would use net label, i don't see the problem.
QDrives , 04-12-2024, 04:00 PM
If all your Vin_xx pins connect to a single net, you just provide that netname to the pin.
"...followed by decoupling capacitor to with Bus." -- Decoupling and bus?
But if you want you pins to netnames and or ports, just copy the pins (plural) and use smart paste. https://www.altium.com/documentation/altium-designer/schematic-placement-editing-techniques#smart_paste
Robert Feranec , 04-13-2024, 05:46 AM
you can just use net, connect all the pins together and connect the net to the port. it looks like you are not using net, but bus, that is not what you want
