Switching Power Supply Course _Lesson 5_polygon
flyforward , 02-26-2016, 12:34 PM
Hello everyone,
I am taking switching power supply course and reaches to lesson 5 using copper polygons. I have a problem that i cannot draw a correct polygon even though i changed the setting according to Robert's lecture as shown in the attached figure. Could anyone tell me what is wrong with that? I have a hard time to upload my design file here. Does anyone know how to do it?
Thanks,
Bin
mairomaster , 02-26-2016, 03:46 PM
Hi flyforward,
From the polygon properties try to set a net in the Connect to Net field and in the drop-down menu under that choose Pour Over All Same Net Objects. Hopefully that should make it pour properly. Here is an example screenshot:
robertferanec , 02-27-2016, 02:30 AM
@flyforward, did you try @mairomaster's suggestion? I also think that is what you are looking for.
flyforward , 02-27-2016, 08:19 AM
Thank you @mairomaster and @robertferanec. However, this did not solve my problem. After setting up what you suggested, i still can not get a closed polygon as shown in the attachment.
mairomaster , 02-27-2016, 08:22 AM
My scrrenshot was just an example. In your case you have to connect the polygon to net PHASE2.
flyforward , 02-27-2016, 08:35 AM
I am sorry. I made a mistake. But it is still not working as attached. orz!
robertferanec , 02-27-2016, 12:08 PM
I do not have Altium available (I am travelling ... again), but it may be, that you need to set Polygon Connection Rule to DIRECT?
flyforward , 02-28-2016, 09:14 AM
Hello Robert,
I finally figured out what is wrong. I mistook setting the power plane connect style rather the polygon connect style.
Thank you very much for you and @mariomaster.
Bin
mairomaster , 02-28-2016, 10:46 AM
I'm glad that you solved the probled. So how was your polygon connect style setting set?
flyforward , 02-28-2016, 11:28 AM
It was set to "direct". Thank you for your help.@mairomaster
robertferanec , 02-29-2016, 08:52 AM
Perfect! Glad to hear you solved it
