Uploading Linux into i.MX6 Rex module without Base Board !!
saeid , 07-15-2020, 06:30 AM
I watched the Robert video ( Bringing up i.MX6 Rex Board to Life) in which he tested iMX6 Rex module without a Base board ! He uploaded the Linux into the module and then Linux was booting, so I have 3 questions:
1. How does the Linux upload in the module that doesn’t have SD card and eMMC?
2.What are the pins of module that allow us to upload Linux without a Base board?
3.Would it be possible to test DDR memory without a Base board? if so, How would it be possible?
robertferanec , 07-17-2020, 05:21 AM
I do not remember exactly as we only used it once, but I believe you can upload everything through MFG Tools (uboot & linux).
This is just to give you an idea (from MFG tools config):
Source:
https://www.imx6rex.com/open-rex/sof...setup-mfgtool/-------------------------
<LIST name="OpenRex-uBootOnly" desc="Only boot u-boot.imx">
<CMD state="BootStrap" type="boot" body="BootStrap" file ="u-boot.imx" >Loading u-boot</CMD>
<CMD state="BootStrap" type="load" file="firmware/fsl-image-mfgtool-initramfs-imx6qdlsolo.cpio.gz.u-boot" address="0x12C00000"
loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" ifdev="MX6Q MX6D">Loading Initramfs.</CMD>
<CMD state="BootStrap" type="load" file="firmware/fsl-image-mfgtool-initramfs-imx6qdlsolo.cpio.gz.u-boot" address="0x83800000"
loadSection="OTH" setSection="OTH" HasFlashHeader="FALSE" ifdev="MX6SL MX6SX">Loading Initramfs.</CMD>
<CMD state="BootStrap" type="jump" > Jumping to u-boot. </CMD>
</LIST>-------------------------
Notice /fsl-image-mfgtool-initramfs-imx6qdlsolo.cpio.gz.u-boot
When you google for more info, you can find this:
https://community.nxp.com/thread/470979Hope this helps.
2) USB
3) Yes (there is stresstester application what can be uploaded through MFG Tool
https://www.imx6rex.com/software/how...ation-on-imx6/ ) - that is a basic test but should be good enough before running a proper Linux with for example stressapptest:
https://www.imx6rex.com/software/str...stressapptest/saeid , 07-18-2020, 11:32 PM
Thank you so much dear Robert for comprehensive answers.
