TinyRex LVDS Display
blueprint , 08-16-2021, 09:16 AM
I'm trying to figure out what changes would be necessary to disable the HDMI display and enable the LVDS display (single channel)?
Also, if I want to change the resolution of the display in u-boot (as well as enabling LVDS), can this be done using the environment variables or do I need to rebuild and re-flash u-boot? We are targeting a micro-display with an 800x600 resolution.
Thanks in advance!
marek , 08-22-2021, 09:49 AM
Enabling/disabling/configuring display outputs is possible over kernel command line. Best source is official documentation (https://www.nxp.com/webapp/Download?...0-LINUX-DOCS):
HTML Code:
i.MX_Linux_User's_Guide.pdfi.MX_Linux_Release_Notes.pdfi.MX_BSP_Porting_Guide.pdf
Some examples:
The kernel command line for 24-bit LVDS panel (4 pairs of LVDS data signals) displays
the following line if the panel is properly connected:
HTML Code:
video=mxcfb0:dev=ldb,if=RGB24
The kernel command line for 18-bit LVDS panel (3 pairs of LVDS data signals) displays
HTML Code:
video=mxcfb0:dev=ldb,if=RGB666
Tells the kernel/driver which resolution/depth and refresh rate should be used for display port 0 or 1.
See the parameter information under Documentation/fb/modedb.txt
HTML Code:
1. video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 video=mxcfb1:dev=ldb,if=RGB6662. video=mxcfb0:dev=ldb,if=RGB666 video=mxcfb1:dev=hdmi,1920x1080M@60,if=RGB243. video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB244. video=mxcfb0:dev=ldb,if=RGB6665. video=mxcfb0:dev=lcd,CLAA-WVGA,if=RGB6566. video=mxcfb0:dev=mipi_dsi,TRULY-WVGA,if=RGB24
LVDS support in u-boot is untested. This change will definitely require u-boot recompilation.
The "board/freescale/mx6sabresd/mx6sabresd.c" is NXP reference platform and it contains support for "Hannstar-XGA" with is lvds panel. This source code must be ported/copied/modified including surrounding configuration. But there is still chance that it won't work as intended.
