robertferanec , 04-28-2020, 03:07 AM
I am not expert for power electronics, but personally I would still maybe try to isolate the power electronics somehow from the rest of the circuit (islands, location, etc). If you just use separate ground layers on different positions in stackup, I believe, the noise from the grounds still could in some cases "jump" to the other planes or signals routed close to that planes and the result could be maybe even worse comparing to using all GND planes in stackup for both (power and also control circuits). But as I said, I am not expert for this, I may be wrong.
Please, anyone with experience in designing power electronics? I would be also interested to hear some thoughts on this topic.Thank you
Mehrdad, 05-02-2020, 09:58 AM
Thanks, Robert for your comment. You are not an expert for power electronic but everybody knows how competent and qualified you are in PCB layout for the processor-based board. When you are talking about jumping noise to other planes what kind of coupling you are talking about? I think you are not talking about the conductive coupling.
