robertferanec , 05-11-2020, 06:37 AM
Note: Normally I set differential pairs in Schematic.
Answer:
If you change or set some properties in PCB and you would like to keep them when you sync schematic, then go to Project -> Project Options -> ECO Generation and you may want to set some of the things to Ignore (these things will be ignored when you will be transferring your Schematic into PCB):
Hung, 05-11-2020, 08:41 AM
Dear Robert!Thanks u so much, I solved it
