Minimum and maximum clearance
Norbert , 11-22-2016, 06:43 PM
Is there a way to set a rule for minimum and maximum clearance at the same time. I would like 2 traces to have a minimum spacing 0.1mm and a maximum spacing 0.4mm.
Thank you
mairomaster , 11-23-2016, 01:44 AM
I think that is a bit unusual, why do you need to do that? Maybe there is an alternative solution.
The standard clearance rule allows you to only set minimum clearance. If the tracks are a part of a differential pair, you can use the differential pairs routing rule to set a maximum gap. If they are not, you can present them as a differential pair, although it will be a bit strange. This is the only way I can think of.
robertferanec , 11-24-2016, 09:38 AM
I would also do it as @mairomaster suggested - differential pair rule.
