Originally posted by
robertferanec please have a look at the HDI document attached to the lesson 2 (scroll down to Download section). It could help you.
Where exactly? I haven't found any section regarding drill-pairing recommendations.
robertferanecHave a look at the
video, you will immediately understand what I mean.
The video confused me even more, since they didn't show how and when drill the via or plate it with the copper
But luckily, your description was clear. Now, on the example of iMX Rex module, I imagine the procedure is as follows:
1. Stack up cores named Dielectric 3, 9, 5 and 11 with the pre-preg layers in between and laminate. These are layers L3, L4, L5, L6, L7, L8, L9 and L10. Of course, all before stacking, all the copper traces are etched.
2. Drill the buried vias from L3 to L10. Plate it with the copper.
3. Stack the pre-preg at the top and bottom and copper foil on top of that. Now we have layers L2 and L11.
4. Drill the microvias (pairs L2-L3 and L10-L11). Plate the microvias.
5. Add the core on top and bottom with the coppler layers L1 and L12 and laminate again.
6. Drill the microvia pairs (L1-L2 and L11-L12) as well as TH vias. Plate with copper.
7. Add the solder mask.
If I understand it right, this procedure needs 3 lamination sequences and 3 drill sequences. This is I believe the measure of cost and complexity in PCB manufacture.
