Stackup problem!
mshakeri , 04-29-2018, 07:06 AM
Hi
I have a EVM PCB file from Spectrumdigital and I want to edit it for specific usage. But I have some problems with Stackup:
1. When I check the DDR2 section I saw that for differential 100ohm impedance they use 5mil, 5mil for clearance and trace width and also 5mil for 50ohm single end but I can not get this impedance value with dielectric thickness changes! Only if I set the Er=2.5 the impedance is equal to 100ohm for differential and 55ohm for single end traces. But in the PCB file they explained the dielectric material is FR-4! Is there any FR-4 with Er=2.5?
2. The layers that used in the file is different from stackup table that exist.(The ground planes is not same, and also layer count) I use the stackup table information for impedance calculation.
Here is evm main page: http://support.spectrumdigital.com/b...vmdm6467/revf/
Here is evm PCB file: http://support.spectrumdigital.com/b...ayout_RevF.zip
This file was designed in Orcad and P-CAD and I imported it in Altium. It may be a problem for stackup changes!
Have anyone a Stackup calculator to help me.
Thanks
robertferanec , 04-29-2018, 10:18 PM
Did they include the exact stackup description (in PCB or as separate file)? I do not have PCAD to check it. Sometimes the PCB file may not have the stackup set correctly.
mshakeri , 04-30-2018, 12:06 AM
Thanks for your quick reply, No there is not any file about stackup.
robertferanec , 04-30-2018, 08:49 AM
Ideally, you need to know the exact stackup from their PCB manufacturer to be able to re-use their track geometry and manufacture your board then.
