Hello, I'm new with designing. Can i get some reference design and guide line for interfacing EMMC memory?
Paul van Avesaath , 01-29-2019, 12:18 AM
that's a bit vague.. but first select your chip.. then read the datasheet.. it should be all in there...or just use google... EMMC PCB guidelines... should give some clues..
robertferanec , 01-30-2019, 12:34 PM
It really depends on chips which you use. Find a reference board with the CPU you are using and which also has eMMC - this way you will know that it will work and also you will have software support for it.
