ESP32 wont connect to my computer
The Chosen One , 02-04-2025, 01:58 PM
So, I designed and manufactured this PCB, and I soldered it up. I am trying to connect the esp32-s3 to the aurdino IDE, but when I plug it in via usb-c, it for some reason is not being recognized (as in, its as if I am not even plugging it in).I just want to make sure its not a schematic error and is something else.Attached also is the project itself.
QDrives , 02-04-2025, 10:27 PM
Where is your pull-up / down on the USB line to indicate what you are?And even though I am almost always a metric guy, schematics are best in 100mil grid.
The Chosen One , 02-05-2025, 12:22 AM
Yeah, I get told that a lot buts it’s because of copy and pasting from different schematics sheets
The Chosen One , 02-05-2025, 12:23 AM
Even on a board with those 5.1k resistors attached to CC1 and CC2 to ground I still don’t get any readings
QDrives , 02-05-2025, 02:02 AM
No, I am talking about the 1.5k(?) Pull-up/down on D+/- to indicate low, full or high speed.
Robert Feranec , 02-05-2025, 12:29 PM
what kind of cable / connector do you use? looks like this connector only has 1 pair of USB? maybe did you try to flip the cable?
The Chosen One , 02-06-2025, 08:05 PM
I tried 5 different cables, I am confident it is not the cable
The Chosen One , 02-06-2025, 08:06 PM
Havent thought of it and Im not quite sure how to implement this, but I definitely will try to for the next iteration
QDrives , 02-06-2025, 08:19 PM
It is **not** optional, it is a requirement for the host to detect the peripheral.
The Chosen One , 02-06-2025, 08:24 PM
Do you have a video I can look at to implement this?
I swear I have seen USB-C's used to connect to hosts before that didnt include these
QDrives , 02-06-2025, 08:25 PM
https://beyondlogic.org/usbnutshell/usb2.shtml
USB-C is just a connector.
You are using USB 2 connections in that connector
