Ethernet Connector Pin out for J1B1211CCD
Clarice Starling , 11-23-2024, 09:34 PM
I will use the Ethernet jack coded J1B1211CCD and drawing the example given by WIZNET.
The names of all the pins are not written in the datasheet. Does the pin order I made seem correct?
My image from TOP
Example : https://docs.wiznet.io/img/products/w5500/w5500_sch_v110_use_mag_.pdf
Connector : https://www.wiznet.hk/en/index.php?controller=attachment&id_attachment=2
Clarice Starling , 11-23-2024, 09:35 PM
My connections
QDrives , 11-23-2024, 09:57 PM
The encircled pin is pin 3.
Just look into a modular jack connector and see how the pins (to the cable connector) are bent.
For soldering we cannot get that close together so the pads are placed in a zigzag pattern.
In this case odd it bottom and even on top.
Clarice Starling , 11-23-2024, 10:00 PM
Thank you so much 🙂
