MIPI CSI & DSI
Jo Engineer , 07-30-2026, 04:42 AM
Hello everyone
I want to make a SBC Board using RK3576 but I have a question in MIPI section (CSI & DCI Connector)
I found 2 resources or schematics for the projects on RK3576 but the connector pin number is differnce ?
I know about what using in raspberry pi is 30 pin but why in the secound photo they using 31 & 40 pin ?
, 07-30-2026, 04:43 AM
The variation in MIPI connector pin counts (30 vs. 31/40 pins) comes from different design requirements and signal grouping strategies. Here's why this happens:
1. **Signal Requirements**: MIPI interfaces need differential pairs (clock + data lanes), power, grounds, and control signals. A 30-pin connector might handle 4 data lanes + clock, while larger connectors (31/40 pins) could add:
- Extra grounds for noise reduction ([source](https://www.youtube.com/watch?v=X-qubBLJDD8&t=1311))
- Reserved pins for future expansion
- Additional power rails
2. **Physical Layout Considerations**: Connector pinouts often mirror the physical component layout to maintain signal integrity. For example, differential pairs are kept adjacent in both schematic and PCB layout ([source](https://www.youtube.com/watch?v=qJd_BMDNfrk&t=1441)).
3. **Manufacturer Variations**: Different connector vendors (Molex, Hirose, etc.) may use proprietary pin counts for similar interfaces. Always check:
- The RK3567 datasheet's recommended connector
- Reference designs from Rockchip
- Connector datasheet's current rating ([source](https://www.youtube.com/watch?v=bC-PIlXXPOI&t=0))
Key action items for your design:
1. Use the *exact* connector specified in RK3567's hardware guide
2. Match differential pair ordering to PCB routing requirements
3. Include 1 ground per 2-3 signal pins for return paths ([source](https://www.youtube.com/watch?v=X-qubBLJDD8&t=1620))
4. Verify maximum current per pin if carrying power
Without seeing your specific schematics, this is the general guidance from available video content.
Would you like me to explain any particular aspect of MIPI interface implementation in more depth?
Robert Feranec , 08-07-2026, 11:55 AM
what are you going to plug in? use the one that will be direct connector for the peripheral you will be using or what most people are using
