Gaskoin , 10-11-2024, 12:13 PM
Hi!I am desining a rocket computer for flight stability, altitude measurement, tracking, recovery and so on. I need all components to be relatively small so the less ICs the better. Power lines looks here like below:- 1s to 4s LiPo battery input (3,7 V - 14,8 V)- 500 mA 3,3 V rail for MCU, sensors and telemetry- 4A 6 V rail for servosI have considered few solutions but I do not know what is the best approach to take here:- 2 x buck-boost for each rail- 1x buck-boost for 6V and then LDO for 3.3 V. I would need some higher current IC as TPS63070 is 4A only- 1x double-output DC-DC converter (couldn't find the IC though)- resign from 1s LiPo support and use only buck converters with one of above setups as they are usually higher current rated. I want to avoid that if possibleSchematic attached for broader view. Thanks!
