Daniel , 08-11-2026, 12:07 PM
Hi Everyone,I am developing a circuit board with an ESP32-S3 and an ST25R100 that is designed to read 5 antennas (30x30mm, 4 turns, 0.8mm width, 0.5mm spacing) sequentially via two multiplexers. I want to use it to read NFC tags placed directly on the antenna at a maximum distance of 2 or 3 cm.I used the ST25R Antenna Matching Tool for the calculations. However, I have absolutely no experience with NFC yet, so I wanted to ask for your opinion on whether this could work.Thanks!
