Dear All,
Thank you for your answers. We perform a lot of tests (I work in a very big company) like humidity tests, lot of tests in thermal chamber, EMC, so everything you can imagine. Until now in our previous projects we used DDR3 interface with max 1066MBit/s and in this case we did not have problems with PCBs without impedance control.
We have some 3Gbit/sec interfaces but those signal lines were very short and we could never test with the device connected to it to check signal integrity (the other device is from other automotive supplier and we can not get them).
To asnwer some of your questions:
We have quite big PCBs: now we have a PCB of: 260mm x 100mm
Now we use impedance designed PCBs: we design the traces to have a specific impedance but without impedance control nobody guarantees that it is really e.g 85 Ohm +-10%. We measured with TDR and without impedance control the impedance for a 85Ohm trace is somewhere between 70 Ohm and 100 Ohm, you can never know what you get. I have seen big differences between suppliers too.
We use length matching in every projects (which I support)
We consider also layer stackups at the beginning of all of our projects
But in our new projects we moved to LPDDR4 to a datarate of 3,2Gbit/sec, and I have the feeling that we reached the point where we should begin to use impedance controlled PCBs. But it is difficult to convince managers, because it costs money. That's why I asked you to collect some ideas how could I convince our managers. Now the decision is that we wait until we have a big problem and we can we exciting task forces and we can work again on saturdays
I would go also for impedance controlled PCBs, I fully agree with you. I know Eric Bogatin and Rick Hartley, I have seen many videos from them.
Thank you again
