RTL8367S ethernet switch and Raspberry Pi Compute Module 4
ZynelAbidin , 12-09-2025, 03:14 PM
my normal connection is like this.
I connected the Ethernet pins in the Raspberry Pi Compute Module 4 datasheet to the Ethernet pins of the RTL8367 IC on my pcb, but they did not work.
ZynelAbidin , 12-09-2025, 03:17 PM
I dont want to use cm4-nano board. How can I establish a communication connection between Raspberry Pi Compute Module 4 and RTL8367 microcontroller?
ZynelAbidin , 12-09-2025, 06:58 PM
@Robert Feranec do you have any idea ?
, 03-26-2026, 03:27 PM
Hi any ideas on the above
, 03-26-2026, 03:31 PM
@ZynelAbidin im trying something same type stuck in some placement
Robert Feranec , 03-27-2026, 10:57 AM
but, how did you connect them? don't forget, ethernet is using transformers
, 03-28-2026, 02:06 AM
Basically @Robert Feranec ethernet switcher type any ideas on it.
Robert Feranec , 03-28-2026, 07:48 AM
I mean what pins ... what signals exactly are connected together. There are at least three different "Ethernet" interfaces: MCU to PHY, PHY to Transformer, Transformer to Connector ... I just would like to know which of these interfaces were connected together between the switch and Raspberry Pi. Because sometimes people try to connect for example RGMII together
, 03-31-2026, 05:22 PM
Sp basically I m trying to use 2 ICs KSZ8863 and KSZ8081 along with 3 eyernet Jack's @Robert Feranec can you share how can be done
, 03-31-2026, 05:25 PM
How can best be placement done of these 2 Ics @Robert Feranec
, 04-01-2026, 03:22 PM
Mac to Mac you can say @Robert Feranec
, 04-02-2026, 05:51 AM
Can anyone please help in the above
Robert Feranec , 04-02-2026, 06:56 AM
what is Mac to Mac?
, 04-02-2026, 01:22 PM
Sorry just shared with these 2 ics im trying for a ethernet switcher design to make
, 04-02-2026, 05:08 PM
@Robert Feranec
ZynelAbidin , 04-02-2026, 08:44 PM
Hi again. I connect directly the rasp pi 4 eth pins to rtl8367 eth pins and its work
ZynelAbidin , 04-02-2026, 08:45 PM
I didnt use any transformers between pi and rtl8367
QDrives , 04-03-2026, 02:58 PM
The transformer sits between the PHY (RTL8367) and ethernet jack.
