Import Netlist failed to include fiducials
SHR007 , 05-20-2019, 11:08 PM
ORCAD software failed to import fiducials into workspace. Rest all components were available in the "Placement" dialog box.
Any clue why this would happen? .
robertferanec , 05-21-2019, 12:45 AM
What is in the log file (when you are importing, there is a log file)? Any warning or errors?
SHR007 , 08-27-2019, 05:34 PM
Hi Robert
I have attached the project file in the reply. This might help you have a better look.
robertferanec , 08-29-2019, 03:04 AM
When running ERCin Orcad, this is probably the problem "Ignoring this component in netlist"
#1 WARNING(ORCAP-36050): No pins are present in FID1. Ignoring this component in netlist.
You can try to use our search (that is what I did) e.g. look for "ignoring netlist":
And I believe, this may be the solution, in fiducial, create property named CLASS with value MECHANICAL
Let me know if that helped.
SHR007 , 08-30-2019, 10:14 AM
Thank you Robert
After updating the property of the part. I generated the netlist again and also updated the existing brd file.
Eventually, I found the component in "Place -> Mechanical Symbols".
robertferanec , 09-01-2019, 12:14 PM
Awesome
